i thought about and the light is also on if you drive faster than 60km/h
but if you try a full brake the ABS should work normal
problem with esp
- Alltagssurfer
Hi all:
yes, i had the sames probleme and cuestions, the people of renault spain, says they couldnt install the boton in my 2001 scenic -i dont have thebotton from origen-, because of my car doesnot have asr.
they give the same information to others members of our web at other places of spain.
I dont know if is true...
so, i just unplugged the Fuse for -extrem- use., but the probleme when you do that, is that the red ligths of stop + brakes + the yellow ligths of service turn on and my speedmeter dosent work in that case.
any ideas? does it hapen to you also?
Nice foto Jureen, how does the scenic develloped in the sand?
can you drive trough for long time?
I neve r done it, and im planning to go mauritania next year -hopefully!!!!-
Regards to alls,
Rod
Regards to alls,
Rod
