Hi, does anyone have any tips for changing the oil in the gearbox and diff and what grade or type or oil should i use. Also where are the filler and drain plugs located.
Thanks
Minty
Gearbox and Diff oil Recomendations and Tips
- fred ullrich
- Onlinejunkie
- Felgen: Inka
Hallo Minty,
The gearbox gets oil TRX 75W 80W
the drain-screw becomes with 22 NM
the in-filling-screw with 24 NM attracted
The rear-wheel-drive gets oil trans-elf 80W 90W
the in-filling-screw with 18 NM attracted
Data from repair-instruction buchli publishing house.
unfortunately, my Engisch is not very good.
good luck
Fred Ullrich
good luck
Fred Ullrich
Scenix RX4 10/02 &Captur TCe90 Expession
fred ullrich hat geschrieben:Hallo Minty,
good luck
Fred Ullrich
Thankyou.
Any idea of quantities or just you just fill until you reach the filler hole?
