A NICE TIP.......
For all our foreign friends, that also drive
the famous Scenic RX4
Keine Stimmen
Insgesamt abgegebene Stimmen: 0
RX4
A NICE TIP.......
Beitrag von RX4 »
HI,
If alot of you RX4 freaks like to go into mud alot......(LIKE MYSELF)
I would advise that you make an extension of the breather on the transmission up to the master cylinder hieght, you can do this by putting a rubber fuelline hose and clipping to the right hieght!
this is highly recomeneded.......
because all that mud, and dirty mud water will mix in with the tranny fluid and you will have pre-mature wear.........
RX4
Alex
EX-Webmaster
EX-Webmaster
Beitrag von Alex »
It's possible to send me some pictures about that modification?
RX4
Beitrag von RX4 »
ALEX,
Ill try to get in there and get a pic......
be patient.....
RX4
RX4
TRANNY TIP, CONTINUED......
Beitrag von RX4 »
ALEX,
Im attaching a picture which you will see a black square piece on the stop . side ....thats the peice you have to pull out and put an extension on with a small fuel line hose , so mud and water dosnt get it the tranny......
hope you understand?!?!?
RX4
Alex
EX-Webmaster
EX-Webmaster
Beitrag von Alex »
Thank you. I'll check this thing :-)
