DISCS.......
For all our foreign friends, that also drive
the famous Scenic RX4
Keine Stimmen
Insgesamt abgegebene Stimmen: 0
RX4
DISCS.......
Beitrag von RX4 »
How often do you members change the disc's front and rear??
I have changed the twice......with new pads?!?! :roll:
and they are not no-name, there are genuine renault ....both times and the pads???
RSM :razz:
Alex
EX-Webmaster
EX-Webmaster
Beitrag von Alex »
Our RX4 with now 50.000 km is running with the first original discs and pads.
RX4
Beitrag von RX4 »
Alex hat geschrieben:Our RX4 with now 50.000 km is running with the first original discs and pads.
Very strange??
do you do alot of offroading?? like mud,sand salt.etc??
because i do enjoy the hell out of mine......
and I Do pull a small boat......but I cant beleive the excess wear is from the small boats weight?!?!?! :roll:
anyway,
thanks for the reply m8 :D
RX4 :)
Alex
EX-Webmaster
EX-Webmaster
Beitrag von Alex »
No really offroad and only three times of pulling something with max.
1000kg ( i think ).
Zuletzt geändert von Alex am Mo 28. Feb 2005, 09:31, insgesamt 1-mal geändert.
costi
Beitrag von costi »
I have changed the pads once at 30000 and soon I will have to change discs and pads probably at 60000. I am thinking to use K99034MFP6 from http://www.reichhard-motorsport.com/
As I understand your RX4 is modified a bit so you do stress more the brakes
It has to do with your driving stile as well.
RX4
Beitrag von RX4 »
costi hat geschrieben:I have changed the pads once at 30000 and soon I will have to change discs and pads probably at 60000. I am thinking to use K99034MFP6 from http://www.reichhard-motorsport.com/
Costi,
I have considered that due to the fact that mine has 158hp.........
but i cant beleive thats the reason.....I have chatted with some other m8's out here and they have all replaced @ 45,000.........
ill check out the link and see what your recommending .....
thanks.....BTW........
RSM
