costi hat geschrieben:This is a very interesting subject for me.
I have a 2002 2.0 16v with a bit over 50000K on the clock. Only modification done changed the air filter with a Green.
I am very pleased with the car in general terms but ... I want more guts.
Can you please give more details (data, pictures, advice etc) on modifications that you have done to your RX4 especially the ecu.
Appreciate your help on the above
COSTI.......
here are some of the mods ive done.....
ive taken off all the intake manifld and cut of the restricting neck in the plastic neck that slides over the throttle body, its was flat out restricted and was trying to suck air in from a gap of 10-15mm........not good!!
took all that off and it sucks air from all the diameter of the t-body....75mm.....
and out in a free flow k&n filter.
plugs i replaced the plugs with the ones i mentioned in the other post!
and a chip mod ....which you have to do thru a superchips dealer in ausie land m8, because its a seriall programmable car, meaning the mod takes place thru the obd port, we dont touch the actual psop 44 pin dill in the ecu.....by the way i am the exclusive distributor for superchips in greece.........(im not greek, but american......)
and ive put a free flow last can muffer......
im now looking to install the intake manifold complete from the clio sport 172 hp.....due to the fact that the motor @ the head, block meaning motor is excatly the same .......I would love to put the exhaust manifold on too , but I can because of the 4wd tranny in the way........
anyway these are all my goodies....
oh....also i have changed the tyres and put on some larger ones , it pretty awsome in the mud now!!!
and last i really like that avatar of yours..........
PS...NO PICS.....SORRY?!?!
RX4
