Noise between 90 & 110kms
RX4-Salomon
Newbie
Newbie
Re: Noise between 90 & 110kms
Beitrag von RX4-Salomon »
With the noise i have a small vibrations. Do you think that gearbox bearing or rear differential can do vibrations ?
Thanks
Scenic RX4
A Vehicule Lunar
Webmaster
Webmaster
Felgen: 17"
Kurzbeschreibung: Grand Scenic III TCe Dynamique
Has thanked: 5 times
well i think it coult be the differential, because you said you checkt the rest of it all.
It's OK when your Renault makes some Nois.
But be carefuly when it's quiet!
RX4-Salomon
Newbie
Newbie
But i hear a front noise and not really a rear noise... But i'm not really sure... Here many rx4 owners removed completely the rear differencial, they conserve a part of rear driveshaft behind rear wheels and they remove completely the rear differencial... Do you know this solution ?
Thanks
Scenic RX4
A Vehicule Lunar
Webmaster
Webmaster
Felgen: 17"
Well i think it is the differential. Can you change the oil inside the Differential?
RX4-Salomon
Newbie
Newbie
I've already changed the oil of the rear differential
Scenic RX4
A Vehicule Lunar
Webmaster
Webmaster
Felgen: 17"
RX4-Salomon hat geschrieben:For my noise problem, i removed the propshaft and i still have noise between 90 and 110kms... Very strange this noise, it's not a metalic noise, it's like i have a problem with a wheel, but to eliminate the problem i replace my four wheels by anothers, but i still have the noise ??? So i think i have a problem with a bearing gearbox or with the differencial but it's hard to find the origin of this noise... Maybe you have an idea ?
Well when you removed the Propshaft and the noise is stille there, than it can't be the differencial.
Only the Gearbox or the propshafts to the Frontwheels can make the noise, or not?
Webmaster
Webmaster
Felgen: 17"
habe you checked the tension roller?
